I got a penny in ma door! HELP!
well this morning i ran to publix and when i got back in the car....I threw my change in the side pocket of the door....well how about that a penny or something has got in there! How do i remove the panel (The red area i shaded)...
http://i7.photobucket.com/albums/y29.../DSC006089.jpg in this pic the the thing its behind.....the red circle is a little slit, just big enough for a penny to get through! can i remove the pieace in red, in the lower pic? http://i7.photobucket.com/albums/y29.../DSC006109.jpg Im sorry the pics are so big! |
RE: I got a penny in ma door! HELP!
those pics are giant. here's a write-up for removing the front panels. it's very easy. the tricky part is getting the door handle inserts out without breaking them.
http://www.audiworld.com/tech/int13.shtml |
oh my that looks like i could break something
no, it really is very easy. it's just 5 screws. like i said, the only tricky part is the small oval insert in the door handle. when i had my windows tinted they broke one of them, but the guy showed me right away instead of trying to hide it, and you can't even see it when it's installed, so i let it slide. even if you crack them it's really not a big deal.
im looking at the how to thing..where are the two visible screws at the upper corners of the door panel...i dont see them!
they are on the sides of the door. they are inside the door jam when the door is closed
yeah i found the one on the left side of the door but the one on the right side i am still searching, i might call the dealer
i just realized that you have a B6, so you may not have a screw there...the write-up i linked you to above is for the B5..i wouldn't take it to the dealer, unless you've got 100 bucks to drop on getting a coin out of your door. it really isn't too difficult. remove the screws that you can find, and then wiggle the panel slightly to find out where it is still secured.
haahaha
take it to a stereo shop, they will have much experience with taking the door panels off... prolly do it for 20 bucks -- saves you from breaking stuff, and having rattles in your shiney 2005. |
ugh...i dont know what to do!
