I lost this and need suggestions plz
Old Apr 18, 2007 | 02:31 AM
TeeterTawter's Avatar
Default I lost this and need suggestions plz
http://www.walnutcreekhonda.com/imag...WheelLocks.JPG
I lost the peice(key part)that connects to you tire iron and removes the wheellocks.. how do i remove it without the key?
thanks
Old Apr 18, 2007 | 02:33 AM
sdsteez's Avatar
Default RE: I lost this and need suggestions plz
try a wheel shop. i heard a gator wrench works but im not sure without torque......
Old Apr 18, 2007 | 02:42 AM
The Bishop's Avatar
It will have to be removed with a key removal tool, a local tire shop should have one. Basically it's get hammered on, and turned off. You can't order a replacement key unless you still have the original serial number from the wheel locks.
Old Apr 18, 2007 | 02:46 AM
unfortunatly im a retard and threw the orignal packaging away and cant find the receipt.
Old Apr 19, 2007 | 04:08 AM
went to 2 wheel and tire shops today, both tried this tool they have that they hammer on and then removes them, well, did not work for either of em. both said it will have to be drilled out. any other suggestions b4 i actaully do decide to drill it out.
Old Apr 19, 2007 | 04:15 AM
java's Avatar
if you weld or know someone who does, weld a nut onto the top of the lugnut, you could also try one of the universal sockets that have all the little wire like things inside it, there only like 10 bucks and it might be worth a try.
Old Apr 19, 2007 | 05:00 AM
CLX's Avatar
CLX
Zombie Defense Force
Welding onto chrome plate is always a bad idea. You could try drilling and then tapping them with a left-hand thread bolt, and then knocking them off that way.
Old Apr 19, 2007 | 12:12 PM
Bondga's Avatar
generally there is only so many patterns for wheel locks. go search through some kits until you find the one that fits yours, unless you bought them high dollar fancy ones.
take a pic of the lock, sometime there are common tools that can remove them
Old Apr 19, 2007 | 12:49 PM
new2me's Avatar
If there is the space a pair of vise grips and a pipe might work.
Old Apr 20, 2007 | 10:18 PM
I got them off . brought the audi to my fathers place, he used a 3/4 inch hex impact socket and a big hammer. no damage to the wheel but the socket is a lil dinged up.
