I love my dealership...sometimes.
Old Sep 8, 2006 | 02:22 PM
a4sport's Avatar
Default I love my dealership...sometimes.
My cars been running really rough lately. I assumed misfire. It only occassionally throws a CEL and then if I turn it off it goes away. My car is a 03 1.8TQ and has roughly 72k on it. I purchased it on lease turn in for cheap since it had some front end damage to it that I fixed. Now it's my turn to run through the car and get all the maintenance done on it.
I called the dealer since the problem began and priced out new plugs and coil packs. $162.48 for both. Needless to say, I purchased them today. I think I got a great price.
Gonna replace them and hope that my rough idling goes away. It only does it on cold starts and if I keep turning the car off and back on, it tends to go away when it's been started a few times. Doesn't do it all the time, just sometimes.
If you think it might be something other than just replacing plugs and coil packs let me know. I thought from reading TSB's that coil packs possibly went bad on my car. And for all I know, neither plugs nor packs have been replaced.
Old Sep 8, 2006 | 04:22 PM
InsaneHatter's Avatar
Default RE: I love my dealership...sometimes.
coils i think are 104/ for 4.. and plugs are 60 for platinums.. so i guess you got a good deal, esp from the dealer
Old Sep 8, 2006 | 05:41 PM
chuckievi's Avatar
If it keeps throwing a CEL..... get the code, that will TELL you what your problem is.
Old Sep 8, 2006 | 05:45 PM
techbod's Avatar
I doubt its the coils or the plugs ( sounds like idle problem or cold start ) but without codes you throw the coin
Old Sep 8, 2006 | 06:43 PM
a4sport's Avatar
If my code goes away, does the ECU store it then. It rarely comes on. And when it does, it's when the car is running really bad. After I shut it off, it goes away.
Old Sep 9, 2006 | 03:43 AM
dankhound's Avatar
It should store it for around 40 ignition cycles. So it should be there. Sounds more like an engine coolant temp sensor/ cabon buildup problem.
wildlife9000
Aug 8, 2007 02:08 PM
kurthrob
May 8, 2007 06:05 PM
Yinh_Chieh
Feb 8, 2007 12:45 PM
rezurrected
Sep 29, 2006 08:10 AM
pturbo
Jun 12, 2006 07:42 PM
