i need a vag-com
Old Jan 11, 2007 | 02:28 AM
johnstef's Avatar
Default i need a vag-com
i already have a laptop i just need the vag-com software and the cable. any good ones out there for good price?
Old Jan 11, 2007 | 02:42 AM
akielb's Avatar
Default RE: i need a vag-com
If your just looking to clear codes then go with an Ebay cable - and DL free software from ross-tech -
If your looking to do major changes and want to see everything that has to do with your ECU - buy a $250 cable from ross-tech - your choice
Old Jan 11, 2007 | 02:52 AM
johnstef's Avatar
i just want to like reset things and look at codes. is the cheap one fine then? which cheap cable should i get becasue there are millions and i have know idea which is the right one?
Old Jan 11, 2007 | 02:57 AM
akielb's Avatar
this is the one that I have - does fine for clearing codes
http://cgi.ebay.com/ebaymotors/USB-K...spagenameZWDVW
You can also purchase the full program from them for $100 that will work with the cheap cable. But you get zero tech support.
Good luck
Old Jan 11, 2007 | 09:01 PM
johnstef's Avatar
can you reset your control temp with this....because im getting a new one so need to rest it?
Old Jan 11, 2007 | 10:41 PM
Turbulence's Avatar
just go to ebay and search for vag-com... you can pick up the cable for a decent price
