I think my car broke. Help! (pics inside)
Old Oct 29, 2005 | 10:35 PM
SilvRA4's Avatar
Default RE: I think my car broke. Help! (pics inside)
like everyone else said, your MIL light is on, most likely an emmisions thing, but i would carefully drive it to the nearest service center and have the codes pulled to see whats wrong
Old Oct 29, 2005 | 10:40 PM
QuattroGT74's Avatar
It is probably something minor but take it to a shop so they can pull the codes.
Old Oct 29, 2005 | 11:04 PM
Yuikio's Avatar
Sounds like what happened to me when my ICM popped. All of a sudden, blinking CEL, shaking/vibrating idle, weird (three-cylinder because of misfire) exhaust note. I drove it to the mechanic 8 miles away, being careful the whole time. I'd check that. I think someone found the HUCO ICM on ebay for like 80 bucks.
Old Oct 29, 2005 | 11:15 PM
Fall0ut's Avatar
ORIGINAL: Yuikio
that is exactly what is happening with me
Old Oct 29, 2005 | 11:54 PM
david9999's Avatar
Dear Fallout,
not to sound like an ***, but it is clear that you do not have the basic knowledge to work on your car.
Your best bet is to have it flatbedded to a Euro-mechanic who specialized in Audi or VW and have him fix the problem.
Blinking CEL or MIL is not an emissions problem. If it is blinking don't drive it or engine damage could occur.
Old Oct 30, 2005 | 12:54 AM
Yuikio's Avatar
Yeah, just get it towed to a mechanic. It's most likely your coilpacks or your ICM. Shouldn't be too bad $ wise.
Old Oct 30, 2005 | 11:21 AM
david9999's Avatar
Dear Fallout,
After you solve this issue, I would suggest that your invest in a manual for your car. You can likely buy one used on ebay. Once you buy it, read it. It will save you lots of money in the long run, by telling you how your car operates, what the warning lights mean, and what basic maintenance needs to be done on your car to keep it running
Old Oct 30, 2005 | 04:27 PM
  #18
AsianA408's Avatar
u need to vag it. im almost sure its a COIL PACK. 1 or 2 outta the 4 that u have is shot.. change them. that will solve the issue.
Old Oct 30, 2005 | 04:47 PM
  #19
Fall0ut's Avatar
ORIGINAL: AsianA408
what are COIL PACKs
btw, your audi looks really nice, were did you get that body kit at?
Old Oct 30, 2005 | 10:36 PM
  #20
John_E's Avatar
As was mentioned earlier:
Steady CEL = a problem exists, but the car may be driven.
Flashing CEL = a serious problem exists, and continuing to drive will damage something.
The most common cause of a flashing CEL is indeed misfire in one cylinder, and this is consistent with your rough engine operation. If you are not getting a spark in one of the cylinders, you risk contaminating your catalytic converter ($$$) and your engine oil.
Pop the plastic valve cover and make sure all four coilpacks are properly seated. A loose spark plug can cause one to pop up.
