Idle Problem. . . Any ideas?
Old May 21, 2007 | 10:43 AM
Audi A Fizzle's Avatar
Default Idle Problem. . . Any ideas?
WhenI start my car in the mornings or whenever it has been sitting for a while (20+ minutes) it has this horrible idol problem. It idols at around 1100 instead of 900like it should for about 2 or 3 minutes, and i hear a loud high-pitched noise from under the hood (usually it does, sometimes it even goes up and down from 1500 to 500). After a few minutes I hear this sound like its winding down and then it idols perfect.
I really do not have any ideas, so any input is appreciated.
Thanks
Old May 21, 2007 | 10:48 AM
kpatz's Avatar
Default RE: Idol Problem. . . Any ideas?
First hunch is either a vacuum leak or a bad secondary air injection pump.
Have you checked for codes?
Old May 21, 2007 | 11:03 AM
Yeah, a vacumn leak was my only guess too.
How do you check for a vacumn leak? YeahI actuallydid run it for codes becausemy check engine light comes on periodically, anywaysI got 4 different codes. . .
2 clyinder misfire codes
- general misfire
-cylinder 1 misfire (i did regap my spark plugs, seemed to help)
fuel system running to lean
can't remember the other one
(i'm at work ehh. . . )
Old May 21, 2007 | 11:12 AM
mikeherman's Avatar
Are we talking American Idol or engine idle?
Old May 21, 2007 | 11:52 AM
ironman's Avatar
WHen you get out of werk check the rubber hoses and see if they are split cracked. Then go sing for simon Cowell.
Old May 21, 2007 | 11:58 AM
haha thanks, I have checked almost all the hoses, atleast all the ones that I can access by simply popping the hood, however i have not gotten under the car or gotten too deep into the engine bay. . .
is there a typical place for the B5 1.8TQ to have vacumn leaks?
Old May 21, 2007 | 12:02 PM
headshok2002's Avatar
The most common one (I think) runs underneath the intake manifold from the front of the motor to the back.
Old May 21, 2007 | 12:04 PM
Alright, thanks for all thehelp so far!
ps. headshok i saw some photos of your car in some other posts, sexy as hell man!
Old May 21, 2007 | 12:09 PM
stacks's Avatar
Isn't this normal warm up period? Mine does the same thing. I thought it was normal.
ORIGINAL: Audi A Fizzle
Thanks dude.
But yeah, as for your possible boost leak... the hose I mentioned is usually pretty obvious when it's leaking. Rig up a temp boost/vac gauge and run the car. Shops can usually do a 'smoke' test for about half an hour's labour.
Your high-pitched whine could possibly be your secondary air pump. To fix that properly, it's expensive. I'm deleting mine. Wait what year is your car? I think SAP's were only on 2000+.
