Ignition Coil Boots Going Bad
Old Nov 7, 2007 | 11:58 AM
Mr_You's Avatar
Default Ignition Coil Boots Going Bad
Hi all,
I'm running into this problem again. I've narrowed it down to the coil boots going bad. I'm not sure how. After we swap them everything is good to go. But before the next oil change I'm having misfires again.
Anyone think this may be related?
"believe it or not my misfires were clutch related. If your clutch is slipping and you have an aggressive tune, the load readings will be way off and the fuel map will be wrong leading to misfires and timing pull."
Thanks!
DocRizk
Dec 31, 2013 12:00 AM
KoolMan
Aug 12, 2011 09:10 PM
schwettyA6
Jun 15, 2008 09:50 AM
b.hasz
Apr 15, 2008 05:03 AM
