ignition system
Old Apr 15, 2007 | 05:28 PM
2003audiA4's Avatar
Default ignition system
hey all, i was just wondering if anyone has a diagram or schematic for a 2003 a4 3.0 v6 ignition system...thanks
Old Apr 15, 2007 | 05:50 PM
techbod's Avatar
Default RE: ignition system
ignition barrel or what??
Old Apr 15, 2007 | 06:04 PM
2003audiA4's Avatar
barrel
Old Apr 15, 2007 | 06:14 PM
techbod's Avatar
Removing and installing lock cylinder
Note[/align]
t
The reader coil for the immobiliser is attached to the lock cylinder and cannot be renewed separately.
t
The lock cylinder must be renewed if the reader coil is defective.
t
When renewing lock cylinder, note immobiliser reader coil specifications
Removing
Unplug electrical connector at reader coil.
Vehicles with automatic gearbox:
Move selector lever to “Pâ€.
Turn ignition key to “Ignition ON†position -arrow-.
Then lift interlock lever -1- slightly and pull locking cable -2- out of ignition lock housing.
All models:
Note[/align]
To remove the lock cylinder the spare key without illumination and remote control function is needed, as removal is only possible using a key with a flat handle.
Turn spare key to ignition “ON†position, thus aligning recess in trim -arrow- with hole in ignition lock.
Note[/align]
The correct ignition lock position is shown without ignition key for illustration purposes.
Insert a steel wire or pin (Ø approx. 1.5 mm) in hole -1- as far as it will go, at the same time pulling lock cylinder -2- with reader coil out of steering lock housing -3-.
WARNING[/align]
The steering lock must not be operated without the lock cylinder, otherwise it would lock up completely. A locked-up steering lock must be renewed.
Note[/align]
When renewing lock cylinder, note immobiliser reader coil specifications .
Installing
Installation is carried out in the reverse order; note the following:
Insert spare ignition key into lock cylinder and turn to ignition “on†position.
Re-insert steel wire/pin -1- in hole on end face as far as it will go.
Insert lock cylinder -2- with reader coil in steering lock housing -3-.
Then pull out steel wire and press in lock cylinder firmly until catch engages audibly.
Plug in electrical connector on immobiliser reader coil.
Turn ignition key to “Ignition ON†position.
Slide locking cable -2- into ignition lock housing until it engages audibly.
Pin assignment on ignition/starter switch
15-
Terminal 15
30-
Terminal 30
50-
Terminal 50
50b-
Terminal 50b
75-
Terminal 75
86s-
Terminal 86s
P-
Park positionpictures got lost on my hd so ill look for them later
Old Apr 15, 2007 | 06:37 PM
techbod's Avatar
[IMG]local://upfiles/12092/8C4CC65527BD45BE8ECAFA184954E76B.jpg[/IMG]
[IMG]local://upfiles/12092/B470BC94CDEB4D50A210E7D68B40434F.jpg[/IMG]
[IMG]local://upfiles/12092/564CA097D7BD48F2BD633867028898EE.jpg[/IMG]
[IMG]local://upfiles/12092/B73E5654A377432586442F760CC88699.jpg[/IMG]
Old Apr 15, 2007 | 06:40 PM
techbod's Avatar
even your main dealer wont give you this information
Old Apr 16, 2007 | 12:41 AM
2003audiA4's Avatar
thanks till next time
bejum95954
Aug 2, 2022 04:39 AM
Sonita
May 3, 2015 05:58 AM
Shorbatron
Aug 16, 2010 09:58 PM
agazoo
Aug 10, 2010 01:44 PM
jcyj2
Apr 17, 2008 09:41 PM
