I'm new and want some advice...
Old Sep 20, 2007 | 02:48 AM
arem's Avatar
Default I'm new and want some advice...
I'm brand new and considering buying an Audi A4 Quattro, but since I know zero about Audi, I'd like to draw on the knowledge and experience of the collective.
Is this car a good deal?
How much would you estimateto fix the cosmetic damage?
What can I expect as far as future costs involved with this car?
I know these are all noob questions, but I know nothing...seriously.
Basically, would you buy this car if you were me, and how much should I expect to put into it...
Thanks alot guys.
[IMG]local://upfiles/42147/57448A1B05A3491BAB50527533721DAE.jpg[/IMG]
[IMG]local://upfiles/42147/A53DBEA9358249AF82B8BCD8AC339C6F.jpg[/IMG]
Old Sep 20, 2007 | 03:03 AM
qUaTtRoA4's Avatar
Default RE: I'm new and want some advice...
that looks like over 5k in damage if you took it in to have it fixed professionally...you are a fu<king retard if you buy that piece of ****...
don't buy someone elses problems!...
that is not the car for you...move on
gl!
Old Sep 20, 2007 | 03:05 AM
kolan67's Avatar
negative
Old Sep 20, 2007 | 03:07 AM
chaos92287's Avatar
you need to find out a few things.
-is there any damage other than just cosmetic?
-was the timing belt changed for a second time? (if not done DIY it'll run close to a grand and needs to be done between 140k-160k)
if thoes two things check out then you could pick up a replacement fender, bumper, and hood from a junkyard or www.shokan.com for cheap and get yourself a pretty good deal, but i would try and haggle him down a couple hundred
Old Sep 20, 2007 | 03:09 AM
chaos92287's Avatar
if ur not a DIY kinda guy tho then pass it up
Old Sep 20, 2007 | 03:10 AM
TeeterTawter's Avatar
^^^^+1
Old Sep 20, 2007 | 09:16 AM
The Bishop's Avatar
WAAAAAAYYYY too much fluid on the ground. Back away.
Old Sep 20, 2007 | 10:49 AM
ironman's Avatar
these boots are made for walking!!!
Old Sep 20, 2007 | 10:59 AM
fireWire's Avatar
probably only worth 700 bucks tops. run for the hills!
Old Sep 20, 2007 | 02:09 PM
ocadam's Avatar
Walk-away...and its a 2.8
