Inaccurate temperature reading
Old Aug 3, 2005 | 08:09 PM
A4Petro's Avatar
Default Inaccurate temperature reading
Hi all, I was wondering if anyone had a problem with their temperature reading that appears on the computer between the guages. My reading is always 5 to 15 degrees over what it really is, does anyone have a solution or any idea how i would be able to fix this or is this a normal thing for audi a4's. thanks for the input.
Old Aug 3, 2005 | 08:27 PM
Jestnomen's Avatar
6th Gear
Default RE: Inaccurate temperature reading
Might need to replace the temperature sensor located on the front radiator.
Old Aug 3, 2005 | 08:46 PM
BFlan2001's Avatar
no, he's talking about the outside temp gauge...mine is always too hot as well, it's because the sensor is in the center of your black dash that is in the sun all day, so it's not exactly accurate. i don't know of any way to adjust it, it's kinda worthless IMO
Old Aug 3, 2005 | 08:50 PM
A4Petro's Avatar
Yea i meant the outside temp...well i guess no solution to that problem, thanks for the help!
Old Aug 3, 2005 | 08:51 PM
Jestnomen's Avatar
6th Gear
uh, that is the sunlight sensor, not the temp sensor on your dash. The outside temp sensor is on the radiator front.
Dave666's Avatar
Yea it depends on how the sun is hitting it
Old Aug 3, 2005 | 08:52 PM
BFlan2001's Avatar
jest, was yours accurate on your old B5? cause mine is always at least 5 degrees hotter, sometimes more like 10
Old Aug 3, 2005 | 08:53 PM
Jestnomen's Avatar
6th Gear
The sensor on the dash is used by the climate control to vary the temperature by how strong the sun is shining.
Old Aug 3, 2005 | 08:55 PM
BFlan2001's Avatar
gotcha, but do you think if the reading is always off by a few degrees that it's bad or is that normal?
Old Aug 3, 2005 | 08:58 PM
A4Petro's Avatar
kinda confused but...im guessing i need to replace the sensor by the front radiator..
