Increasing fuel delivery
Old Jan 3, 2005 | 02:35 PM
mattd860's Avatar
Default Increasing fuel delivery
Ok, I've posted the same thread on audiworld.com so If you see this twice - forgive me.
Anyways,
I work for a supercharger company (Opcon Inc, which owns Autorotor and Lysholm). I can do all the work to fit one to my car. All I need is to increase fuel delivery (I think) which is not possible by going through the Stock ECU. So are there alternative methods to increasing fuel delivery?? I don't care if it flips the engine light on as long as it works with the supercharger. Any suggestions??
Old Jan 3, 2005 | 02:39 PM
Jestnomen's Avatar
6th Gear
Default RE: Increasing fuel delivery
Stand alone engine management, larger injectors. If you work for a supercharger company, wouln't just about everyone there have an answer?
Old Jan 3, 2005 | 02:44 PM
mattd860's Avatar
You would think. But we just make the supercharger and not the kits. And the question really isn't should I increase fuel delievery as I know the answere is "yes", but the question is HOW to do it on a 1996 A4 12v. Please correct me if I am wrong, but will bigger injectors be enough for the supercharger??? Can I adjust the amount of fuel with aftermarket injectors??
Old Jan 3, 2005 | 02:48 PM
Jestnomen's Avatar
6th Gear
I saw you posted on the 12V forum. Look for the user "1PissedOff90". Send him an email. He is the guru of such knowledge of the 12V engine. Honestly I'm not sure how to answer your question thoroughly. Make sure if you email him you put the word "Audi" in the subject line (spam filter).
Old Jan 3, 2005 | 02:52 PM
mattd860's Avatar
thanks - I've e-mailed him a bunch of times but I get no response. I put "Audi" in
the subject line. I'm sure he's just really busy.
Old Jan 3, 2005 | 03:21 PM
Jestnomen's Avatar
6th Gear
yeah give home some time, he's always busy.
Old Jan 3, 2005 | 04:27 PM
alejandrorodrigu's Avatar
ok, buy the rs4 fuel pump and the rs4 fuel injectors, and you can get about +35% fuel injection, but maibe you can not start your engine at the morning if you live in a cold state
Old Jan 3, 2005 | 10:55 PM
Jestnomen's Avatar
6th Gear
Going to require a lot more than that alejandrorodrigu. The stock ECU will just not be able to handle.
Old Jan 3, 2005 | 11:02 PM
flyboy's Avatar
They make a fuel pressure regulator that is also attached to the manifold and measures the boost. This is used on similar aplications, for fuel injected, normaly asperated engines. It increases the fuel psi. per lb of boost. don't know where you could get something like that, It came in kit.
UMONTANA_dual
Apr 14, 2012 09:09 PM
Audi 2000 a6 2.7T
Jan 5, 2010 10:46 AM
Prizmatik
Oct 20, 2009 04:36 PM
audidude89
Jul 1, 2009 02:04 AM
krabben
Mar 9, 2005 02:34 PM
