Injectors
dude you cant just throw on bigger injectors. You need proper ecu tuning to compensate Air and TIMING to make it usefull. Otherwise youll just run rich. An intake isnt gunna compensate for the added air that is needed, and theres nothin you can do for timing without a remap in the ecu.
Thats why APR and GIAC have "big injector" files for the ecu. APR Stage 1+ is one and the GIAC FX file is one. Both of which are only available for the B6 that im aware of.
sticking bigger injectors on makes the ECU compensate but not by much so you wont get the full benefit that's why the system needs remap but you need to look at all the issues ( not like he who puts a noisy exhaust on and thinks hes going faster ) when hes not
No the ecu does not compenstate.. As far as the ecu knows there are still stock smaller injectors on there.. It does not know about the extra fuel the big injectors are allowing to put out until you get a CEL from running rich/flooding the cat with unburt fuel etc. If it was safe or made an effectivedifference everyone would be doing it.
