Injectors
ORIGINAL: NuYorka103185
EVOMS has a big injector file for the B5. We have been down this road before. Thay say they do you guys say no one does.
Dave-the ecu is not as smart as you think it is... Its not going to remap your fuel trim, air, and timing just because there is more fuel being dumped in. It will adapt minimalyuntil a set parameter is exceeded and then it will throw a CEL. You will foul up your spark plugs, clogg your catalytic converter, get poor mpg, among other longer term side affects. Just because you put big injectors in does not mean the ecu is going to adjust the "F-A-M" in a way that is beneficial. The ecu recognizes when it is aked to over adapt or over compensate for one of the key elements that makes for a good combustion, and that is when a CEL pops up, fault codes are stored, or you go into limp mode...
xxipsxx
Dec 11, 2010 03:13 PM
MC Hammered
Feb 4, 2008 12:06 AM
