injectors help with mbc.....???
Old Sep 25, 2007 | 11:14 PM
auditurbo381's Avatar
Default injectors help with mbc.....???
doing the mbc with diode on the B6. cincytt seemed to hint that if im going to try and run close to 17-18 would injectors help with lean. or would i need the 5 bar fpr.... any help i appreciate it. i know it might damage the ol K03. but its all fine and dandy i have a backup. just want to do some tests and will report back to the forums. just asking what to expect fuel wise. thanks for your help. BTW anyone use thi gauge!?! let me know. thanks againnnn!!!!!!
boost gauge
Old Sep 25, 2007 | 11:19 PM
cincyTT's Avatar
I'm make believe
Default RE: injectors help with mbc.....???
you need neither for 17-18psi. ALso you wont hurt the turbo on bit
Old Sep 25, 2007 | 11:29 PM
thank you cincy. what are you running on your tt.....
Old Sep 25, 2007 | 11:31 PM
cincyTT's Avatar
I'm make believe
stock fueling and 18-20psi
Old Sep 25, 2007 | 11:46 PM
stock fuel syetens?!?! wow. throw a cel, or overboost code
Old Sep 25, 2007 | 11:57 PM
Bondga's Avatar
i run 18on mine, however i have adjusted a few things with lemmi
Old Sep 25, 2007 | 11:59 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: auditurbo381
never
Old Sep 26, 2007 | 12:07 AM
aggressive? i hope?
Old Sep 26, 2007 | 12:10 AM
Bondga's Avatar
advanced the tiing the torque at idle and adjusted the fuel curves
Old Sep 26, 2007 | 12:13 AM
how did you adjust the fuel curves without remapping the ecu
