Installed GIAX ECU program..but have a question
Yes, quite a difference. Car definitely moves alot quicker..especially right off throttle. However, when I plant my foot in it for awhile, the car seems to be surging upon acceleration. I think this would have to do with the diverter valve ( blow-off ) failing?
If this being the case, which aftermarket valve should I go with to remedy this problem?
Thanks
Thanks
OK, this is the cheapest..BUT..will it be sufficient when I slam a GT28R turbo on her?
ORIGINAL: david9999
Cheapest is the 710N off a TT. Runs about 35 dollars.
I would recommend the forge 007 valve. I run an and got it because it has a lifetime warranty, fully serviceable, can change different springs for different boost levels and its only like $135
ORIGINAL: Beer Mod
Do you still have the stock DV on your car? My GIAC surged at WOT for the first few days then went away...
ORIGINAL: Beer Mod
But on a stock DV it proly will never go away...you need one that will hold more boost
) solution that is proven to give results?I'm having the APR upgrade done on mine and I want to have the DV by the time I get the flash done.....
