Installed my new boost gauge
Old Mar 30, 2007 | 08:26 PM
akielb's Avatar
Default Installed my new boost gauge
Finally got it all installed. Won't have any pics for a while, wife took the digi down to visit her sister. Just to show how much of a dumbass I am, I got everything wired in the tubing ran and everything hooked up. Then I took it out (tell you about it in a minute) when I got back I was going to reinstall the vents, well I had forgoten that they go through the vent housing. So I need to cut the wire again and add some connectors so I can put everything back in[:@]. not too bad of a screw-up but I can laugh at myself and now so can you
the test run - my hg starts at about 19-20 then goes down to 16-17. would this be a vacuum leak or is it normal? when I wot on it I spike at about 10 in first then it drops fast down to 5, 2nd gear it spikes back up to 10 then drops down to 5 again. I think I have a boost leak somewhere - I'll see if I can find it later.
I purchased a 7-color tinted glowshift boost gauge and I did the center vent DIY(using the left most center vent). The red color of the gauge matches perfectly with the red of the dash - very happy so far with the gauge.
Old Mar 30, 2007 | 08:32 PM
Audi_Skydiver's Avatar
Default RE: Installed my new boost gauge
YEAH another one for glowshift! LOL
Yeah I know what you mean about the wires and stuff. I ran mine then accedentlay pulled them back out when I pulled the gauge and had to do it all over again!
Oh and I have a vac leak to. GRRRR but now boost leak!!! YEAH!!!
Josh
Old Mar 30, 2007 | 09:54 PM
cincyTT's Avatar
I'm make believe
Just drove the brothers 1.8t with the glowshift boost guage and it seems to be still running fine after 6 months. And your boost problem is normal. The turbo doesnt hold boost very well unless you have a chip and/or a mbc.
Old Mar 30, 2007 | 10:24 PM
The Bishop's Avatar
YAY. another lefty center vent. I think it looks better. And yea we've all done the wiring before putting it through a hole at one time of another. Now that you know what psi you are running, not having a chip is gonna bug you.
Old Mar 30, 2007 | 11:48 PM
akielb's Avatar
ORIGINAL: thebishop
I actually am "chipped" I just have no Idea by who. see https://www.audiforums.com/m_481031/tm.htm Once im sure that I've dealt with all the leaks (if they exists) I'll think about upgrading my chip.
Old Mar 31, 2007 | 03:08 AM
alias747's Avatar
Hey akielb, maybe I missed it but how did the tip chip from Inmtion ever turn out?
Old Mar 31, 2007 | 07:20 PM
akielb's Avatar
I'm going to try to find my vacuum leaks - I went to autozone and picked up some "carb & choke cleaner" is this what everyone is refering to when they say "use carb cleaner" to diagnose vac leaks?
Old Mar 31, 2007 | 07:25 PM
Yeah I think so. Thats what they told me anyways (Everyone on this forum). I need to go do that here soon to.
Josh
Old Mar 31, 2007 | 08:17 PM
akielb's Avatar
This must not have been the right thing because I just tried it and i sprayed every vac lin and didn't get any increase in the rpm's. I even tried taking off the vac line of my boost gauge and sprayed it into the lid of the cleaner with the vac line in the lid and the engine did nothing. maybe I need somthing a bit more powerful than the brand that I purchased(gumout).
Old Mar 31, 2007 | 08:28 PM
alias747's Avatar
Akielb, did you see my question??
