installing a MBC
Old Jan 25, 2006 | 12:15 AM
audiboy1618's Avatar
Default RE: installing a MBC
Like whats constant?
Old Jan 25, 2006 | 01:07 AM
Peteman187's Avatar
I dont turn mine more than 1--1 1/2 But then again you got a bigger turbo
Old Jan 25, 2006 | 01:21 AM
Jeff's Avatar
Zombie Defense Force
u need to turn it up like 4 turns to have some good fun
Old Jan 25, 2006 | 01:22 AM
Peteman187's Avatar
Damn 4 is waay too much for me. Im so worried about fing something up when I play with that thing
Old Jan 25, 2006 | 01:29 AM
Peteman187's Avatar
O yeah something else. If you have a bleed type (which you do) you can just cut the hose going from the n75 to the wastegate and install your mbc there (thats what I did).
Old Jan 25, 2006 | 01:30 AM
Jeff's Avatar
well when u turn it up watch ur boost gauge and if it get about 20 then get out of it
Old Jan 25, 2006 | 02:36 AM
black991.8tq's Avatar
what boost do u guys thik i should be running at, rite now i hit about 19psi then it drops down
Old Jan 25, 2006 | 03:03 AM
  #18
Jeff's Avatar
just replace the n75 withe the mbc so it goes turbo----mbc----wastegate. and black 991.8tg 19 psi is good, i wouldnt go much higher tell u can find out what ur a/f is, and any higher the longjevity sp? of the turbo goes way down. o wait u have k04 right?
edit ok just read ur sig ya i dont know much about a k04 cus i have never had one but if u turn it up check the a/f and if its all good then turn that boost up
Old Jan 25, 2006 | 03:19 AM
  #19
that is how i planned on runnin it turbo-mbc-wastegate. i just dont want the boost to drop off, will it hold 19 psi all the way up the rpms?
Old Jan 25, 2006 | 03:22 AM
  #20
Jeff's Avatar
well that depends if the turbo can do that, cus some run out of gas, mine will hit at 22psi then drop to 19 now but when i have it up to 30psi it will hold tell i shift
