Installing springs?
Old Sep 25, 2006 | 03:22 PM
EliteTuning1's Avatar
Default Installing springs?
ok so i did my research, i printed out the diy for installing springs, but i still have problems. i have a 2001 audi a4 fwd. i started with the rear wich the diy said to. so i jacked the car up and put it on stands, took the wheels of , and disconnected the lower control arm. then in the diy it say to disconnect the upper control arm. i looked in the wheel well, took the wheel well out and ripped apart the trunk looking how to get this out. my spring and shock just goes up to the body of the car and were it goes in there is not any bolts or anything. can someone please help me out with this.
Old Sep 26, 2006 | 02:45 AM
Mike@PureMS's Avatar
Default RE: Installing springs?
The tops of the shocks are inside the car.
Remove the bottom of the seats, then fold the seats down.
On each side of the seat is a cushion, you need to remove that cushion.
Push down on the cushion, pushing it towards the floor, then you'll unhook the bottom of it, then lift up and unhook the top.
There's a small compartment covered with foam, remove the foam and you'll see the tops of the shocks.
Old Sep 26, 2006 | 02:54 AM
sandman's Avatar
the 2wd rears are different than the awd
Old Sep 29, 2006 | 04:08 AM
how do i remove the little piece on the sides of the seats.
Old Sep 29, 2006 | 04:39 PM
ORIGINAL: EliteTuning1
You have to remove the seat bottoms first, you do this simply by lifting them up. They'll unhook if you pull hard enough.
gibson 01
Mar 24, 2008 04:48 PM
comfort_racing
Mar 29, 2007 01:53 AM
EliteTuning1
Oct 24, 2006 03:32 PM
Sichko
Nov 4, 2005 11:05 AM
cgv988
Jun 14, 2005 01:18 PM
