Intake
Old Jul 3, 2007 | 01:26 AM
98jeep5nine's Avatar
Default Intake
http://cgi.ebay.com/ebaymotors/99-04...25104450QQrdZ1
I want to get this just for the tubing, then replace it with a K&N cone, but how can it fit a 99 A4 AND an 04 A4....
Old Jul 3, 2007 | 01:30 AM
onepoint8tee's Avatar
Default RE: Intake
Theres no way that will fit under the hood of an A4 1.8t.
Default RE: Intake
didnt think so..
and it says its a short ram intake haha not so short..
well i still havent found what i wanted just for tubing so i can add the K&N cone, so.. any reccomendations onepoint8ee
Old Jul 3, 2007 | 01:34 AM
Default RE: Intake
Your stock airbox flows good, and an exposed cone filter will probably not do much for you other than suck in hot air and be loud. You can rig a good heatshield to keep temps down, but youll probably notice more lag down low and a slight loss in low end tq. Throtle response will be better, but Ive tried it and the cons outweighed the pros- if there were any.
You can get a couple elbow pipes to make a U like the evoms intake, or just slap the filter right onto the MAF without any other tubing.
Old Jul 3, 2007 | 01:38 AM
Default RE: Intake
i always thought a CAI minimally increased throttle response and kept temps down somewhat? I want the sound mainly, i think i'm just going to order a boostedtech intake..good idea?
Old Jul 3, 2007 | 01:39 AM
Default RE: Intake
ORIGINAL: onepoint8tee
..or just slap the filter right onto the MAF without any other tubing.
wait, your joking..?
Old Jul 3, 2007 | 01:41 AM
Default RE: Intake
Yeah a true Cold air intake can... But there is no true CAI for the 1.8t- at least in the A4. They are all technically short ram intakes. Air boxes in most cars are restrictive after you start modding, but not so much with the A4- until you get a turbo the size of your head- and the airbox wont fit anymore anyways.
Old Jul 3, 2007 | 01:43 AM
Default RE: Intake
ORIGINAL: 98jeep5nine
No, just take the airbox out, remove the maf, put the maf inbetween the filter and turbo hose. Some 99's have a secondary air pump which a hose is ran from it to the front of the air box. Youll need a breather filter for that hose.
Old Jul 3, 2007 | 01:47 AM
Default RE: Intake
so your saying the carbonio isn't worth the money?
i've never really seen the carbonio up close.. is it a short ram intake with tubing and whatnot? it looks like its just a carbon fiber cover over something that looks like a stock airbox.
But in terms of me wanting the sound and the minimal pros, is the boostedtech intake wise?
Old Jul 3, 2007 | 01:52 AM
Default RE: Intake
The only thing that makes the carbonio costso much is the carbon fiber. Other than that, its just an air filter covered up by a good heat shield that looks pretty. You can accomplish the same thing with a cone filter and good heat shield (search for audizine heat shield.) I dont know about the boosttech intake,but its probably like all the other ones that arent worth 1/4 of the cost. Save your money for something that gives real gains.
