Intercooler obsession! - A4 B5 - UPDATED
Old Apr 25, 2007 | 01:51 PM
Matt_Iliketurbopull's Avatar
Default Intercooler obsession! - A4 B5 - UPDATED
Hi all,
just want to sharean obsession with Audi A4 B5 intercoolers, feel free to educate me if you feel the need.
GarrettFMICLarge, should fit fine under standard bumper with trimming;
http://www.034motorsport.com/product...roducts_id=595
Garrett FMIC Small, should fit fine under standard bumper with trimming;
http://www.034motorsport.com/product...roducts_id=594
PrecisionFMIC (apparenty uses Garrett core), PROBABLY fits under standard bumper - its 3.5" thick.
http://www.nolimitmotorsport.com/prod/AS1021
NEW KIT!
big, fits standard bumper, garrett core, good price.
http://forums.motivemag.com/zerothread?id=3551132
NEW KIT!
http://www.evolutionracewerks.com/
Generally needs aftermarket bumper.
Goodkit to use if don't want to hack bumper-it uses a thinner, wider core
http://www.racetec-us.com/
Well known FMIC kit.
http://www.evoms.com/
Ilike this kit, looks OEM, again no hacking required!
http://www.momentumtuning.com/site/products/evoic.shtml
Kit, not very tall but probably thick and placed in best airflow, again good if don't want to hack.
http://abdracing.com/
http://www.duhengineering.com/fmic/fmic_a4_intro.htm
If you want to go STEALTH I respect Tyrolsport with their fat SMIC.
www.tyrolsport.com
The Godspeed FMIC kitcomes in two sizes,here's a link to a sitefor A4 B5, installing the larger Godspeed (eBay) intercooler; Note; the core (density)likely not as good as brands like Garrett. I'm not sure yet but seems there is two different Godspeed IC's for the larger upgrade core?; the PHOTO on the Godspeed website (L type - which I assume is used as 'the upgrade') might avoid some cutting of the bumper support? - See in/outlet positions with kit. The one on ebay does require hacking to fit, mainly due to its thickness - over 2inches.
http://forums.vwvortex.com/zerothrea...ostid=32156423
Also a Autobahn888 FMIC kit is available (spelling might be wrong)
dont know much about it.
Forge also make a SMIC, don't know how good it is.
Boost factory also make a SMIC, don't know how good it is.
DIY $150, for those who like to really get $ worth!
https://www.audiforums.com/m_382435/tm.htm
There's more IC kits I less desire;
I wouldnot use this one for aSTREET CARas it'snot a BAR & PLATE and airflow is a bit limited through standard front bumper. Bar and plate is good for heatsink capacity.
http://www.xo2racing.com/cart/produc...ucts_id=100050
Greddy- not bar and plate.
APR- recommend fitting aftermarket bumper (not for me).
There was another brand that made SMIC but they had build quality issues (leaks) when I read about them.[/align]
Old Apr 25, 2007 | 07:26 PM
eurokid's Avatar
Default RE: Intercooler obsession! - A4 B5
for when you get that FMIC..here's a DIY
gTT
May 14, 2007 07:57 AM
csuflyboy
May 26, 2006 07:46 AM
