Interior light help
Old Jun 28, 2006 | 04:32 AM
d_maniac's Avatar
Default Interior light help
Well this is not the common electric problem…The lights in my interior wont light up when my driver’s door is open, but will for any of the other doors in the car.
Also the light under the driver’s side dash, OR the red light on the driver side door wont light up either. Is there a fuse that controls these lights that may be blown??
BTW i already changed the bulbs so a blown bulb is not the problem.
Old Jun 28, 2006 | 09:02 AM
david9999's Avatar
Default RE: Interior light help
It sounds like th switch at the door. Check it out.
Old Jun 28, 2006 | 10:43 AM
docurley's Avatar
Yep It's the switch on the middle pillar is faulty.
Old Jun 28, 2006 | 02:07 PM
d_maniac's Avatar
well the switch seems to work fine, turn on and off normally...weird thing is i only have a problem with the driver's door red light and under dash light.
Old Jun 28, 2006 | 02:16 PM
docurley's Avatar
So what you saying is, is that you open any door and the lights come on bar the drivers side and door red light?
If so then I would change the bulbs and see if that is the problem first.
Old Jun 28, 2006 | 02:21 PM
clconversion's Avatar
if all the interior lights are not working I would first check the fuse
Old Jun 28, 2006 | 04:10 PM
d_maniac's Avatar
ok all the door red lights work EXCEPT the drivers door.
If i open the passenger door, the lights in the car will come on and the light under the passenger side dash.
If i open any of the back doors the interior lights will come on
If i open the driver door NOTHIN comes on NOT even the red light on the drivers door, or under the dash
i already switched out the bulbs (buy moving them) and they work...so something else must be the problem, any ideas?
Old Jun 28, 2006 | 04:37 PM
StepUpProductions's Avatar
sounds like its just not sencing that the door is open to me... like when the door opens it opens the circuit telling the car that the door is open and thus turns on the lights for the driver... sounds like that to me
Old Jun 29, 2006 | 01:25 AM
d_maniac's Avatar
anyway to fix this?
Old Jun 29, 2006 | 12:23 PM
d_maniac's Avatar
is there a plug in the door pannel that could be unplugs or messed up?
