ipod wire running
Old Jan 15, 2006 | 05:46 AM
limptimtim's Avatar
Default ipod wire running
Is there any way/write-up on how to run a wire from the headunit to inside my center console (obviously invisible superficially).
I want to be able to keep my ipod in there so I don't have to d/c it all the time when I get out of the car because I don't want people seeing that I have an ipod laying out.
Thanks,
Tim
Old Jan 15, 2006 | 01:59 PM
Silver98A4's Avatar
Default RE: ipod wire running
center console meaning arm rest? i got my wire to the little square compartment here
my armrest is up in that pic, but there's got to be a way to get it up and into it...(might require a little drilling to fit the wire through...) other than that, mine is completely invisible until right behind the seatbelt clip because i needed a little slack on the wire and i didnt opt to drill through the pad in that square holding area and make the wire come straight up.
Old Jan 15, 2006 | 03:40 PM
limptimtim's Avatar
ORIGINAL: Silver98A4
or yeah, center arm rest is what i meant.
Yeah, I would like the wire to come into the box and it would probably require drilling.
Is there a writeup to do this? or up to the drilling part that you made?
I only found an s4 armrest fix on audiworld which will help me slightly.
Old Jan 15, 2006 | 03:55 PM
CRAZYHAWK's Avatar
BestBuy quoted me $25 labor to run wires for an ipod to either the glove box or center console. The wires must be purchased from them. There are two ways:
1. Ice Link Connects to multi-CD changer $200
2. FM Modulator Connects to antenna $78 with DC power
Old Jan 15, 2006 | 04:52 PM
north5995's Avatar
I have the Dension Ice Link. It works really well, no complaints. Took about 10 min to install. Biggest pain in the *** was trying to get the radio out.
Old Jan 15, 2006 | 08:11 PM
limptimtim's Avatar
well, I already have the blitzsafe ipod adpater installed and everything. Right now it's running into my glovebox, but I rather have it in my arm rest so it's closer for me to control.
I'm just not sure how to go about doing this myself.. I rather not take it anywhere
Old Jan 16, 2006 | 12:23 AM
Silver98A4's Avatar
Ok, i don't know if im helping or pointing out the obvious...but this is how I ran my wire, except i came up into that square compartment..instead of going a little further and drilling up into the arm rest.
I drive with my arm rest up...it kinda gets in my way when shifting and gets in the way of the e-brake...So I didnt opt to put my ipod in there..but this is how i would run your wire. Tuck it underneath the material that makes up your center area and meets the carpet
[IMG]local://upfiles/9945/61AF283E740C41E7BB066F3DBC8818B8.jpg[/IMG]
Old Jan 16, 2006 | 01:08 AM
limptimtim's Avatar
I wish I had the luxury of having an arm rest get in the way of my shift, but sadly I have a tiptronic so I like to rest my arm on there
so do i just use a really long hanger? I just wasn't quite sure if i remove some panel to run the wire.
Old Jan 16, 2006 | 01:39 AM
Silver98A4's Avatar
you can just lift it up a bit and push it up and under with like a flathead screw driver
Old Jan 16, 2006 | 03:50 AM
limptimtim's Avatar
alright i'll try that, thanks a lot!
