First off, what year?
Then all depends on how much you want to spend on upgrades. DV would be my first choice. Fairly inexpensive and easy to install. DV= Diverter Valve.
Other than that, just keep up on maintenance.
Congrats on the new car!!! What year and how many miles?
o my dear god. im just gona keep my mouth shut on this one or ill get flamed again. Chip first along with a DV. then intake exhaust and test pipe.
TIP: use the search feature at the top. it really helps out a lot
get a GIAC chip exhaust, K&N filter with modded stock box, forge DV, Testpipe
Wow, thanks for all the tips.
Car has a lot of miles, 169000.
It's a 98, but I got it for $4000, so it was a great deal.
Right away I am going to change plugs and filter, and then also put in new brakes.
Think I should still chip it with this many miles, or just hold off?
RE: Just bought an A4 1.8T Quattro
drive the car for a few months and see how its still running.... if it still feels solid and proper maintainance has been done than i dont see why you cant try a chip.
That's a lot of miles.
I would run it for a short while to make sure she holds up ok and everything is in working order.
Replace the filters, check the hoses, flush the engine and replace the oils & coolant.
Then as long as there's no issues - I would chip it and add a stronger DV.
She'll run like brand new!
