Just bought my (new to me) audi
Old Sep 23, 2007 | 07:36 PM
dmichael's Avatar
Default Just bought my (new to me) audi
I just purchased my new Audi 2000 a4 manual with 85k on it. Drove home 400 miles and noticed a clicking noise from the motor. Along with that the check engine light that popped up. I ran the code and it came up as one of these. 1-timing belt jumping teeth,2- failed camshaft actuator- resistance 10-20 Ohms, 3 blocked oil passage. So I looked around and decided to do the work myself. Did not seem too hard.
So I decided that I had needed to fix the timing belt anyways so I will just replace the camshaft actuator sensor as well. So I took the front of the car off today and just wanted advice from those who know more then I do about this. Are the items im purchasing acceptable products, also can anyone add to my list of parts to replace? Mind that I am on a dieted sort of budget. THANKS!
Water Pump
http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWD1V
Timing belt
http://cgi.ebay.com/ebaymotors/96-01...spagenameZWDVW
Camshaft sensor
http://cgi.ebay.com/ebaymotors/95-06...spagenameZWDVW
Camshaft sensor
Water pump
Timing belt kit
Spark plugs
Flush radiator
Oil/ oil filter
Brake fluid
Build an intake for the car /of/ buy a drop in filter
Old Sep 23, 2007 | 07:55 PM
The Russian's Avatar
Default RE: Just bought my (new to me) audi
the first audi i fixed up and sold to buy this one i bought just about all my parts on e-bay. the way i see it is if it does its job then its good. the only thing is how long will it last and if it will fit well, but i didn't really care bout that because i just wanted to get it running and sell it. i'd say that those would be fine. the one part i would pay close attention to is the timing belt, make sure it fits snug
Old Sep 23, 2007 | 11:53 PM
dmichael's Avatar
ok... any more ideas with parts and such.
Old Sep 24, 2007 | 12:56 AM
hiwords's Avatar
i believe ecstuning has a deal on timing belt and water pump. it's like a whole kit wid many parts
Old Sep 24, 2007 | 11:49 PM
dmichael's Avatar
Just a quick question to go along with this... im about to put on the timing belt and I wanted to know if the gear had to be aligned or left in the spot its at and make sure it does not move.
Old Sep 24, 2007 | 11:52 PM
hiwords's Avatar
the gears have to be in the exact same position as when u took the old belt off. mark them with sumthing. people usually put a scratch on there. if the gears are moved, ur timing will be all effed up and then u would need a new car
Old Sep 25, 2007 | 12:10 AM
dmichael's Avatar
well that sounds great... i think i might just line them up then by turning the crank by hand then. thanks
johnrhopkins
Oct 15, 2014 02:57 PM
soraflair
Jan 27, 2011 07:02 PM
jamezz23
Oct 13, 2010 10:44 AM
shane
May 6, 2005 03:23 AM
Audidriver224
Mar 31, 2004 01:02 PM
