Just bought an needs work
Hey, im new here and new to Audi's in general. Made the switch from DSM's. I just bought a 96 a4 Quattro. Coolant leaks. You can I'll and I'm about 10 mins will leak out onto the passenger side. Floor board. I'm thinking something with the heater core. Can any one give some advice?
"You can I'll and I'm about 10 mins will leak out onto the passenger side."
Um...what? Heater core sounds right if it's leaking in the car...if you're saying it doesn't start till the car is warm that seems even more typical of the core needing replaced.
Sorry...iPhone did that. I meant to say you can fill the antifreeze and it will leak out in about 10 mins. Thanks for deciphering that. And I know a core is about $60 or so. How tough of a job? And when I do it what antifreeze should I use. I was told to only use Audi antifreeze.
Well if you are comfortable removing your whole dash & heater box assembly you will be ok. Takes me about 12 hours.
If you have never done one look at bypassing heater core & putting sign on dash that says "summers coming" or spring some serious cash for someone that can do the job.
Charging $120 an hour at what i do i make sure it is done correctly!
I am very good at what i do!
I am glad you are so fast. You must be proud of yourself for being so great.
I have no problem doing that. Me and my friends always like a nice project. Between 3 guy should be done fairly quick. Just wanted to see how much help I would need to get it done quick or fin out if it could be reached through the glove box. Thanks tho. Appreciate it
