is this a K03?
http://cgi.ebay.com/ebaymotors/96-03...spagenameZWDVW
is it me, or does this look quite larger than a k03?...it looks like the comp. housing is larger, the center cartridge, and mostly the exhaust side looks bigger(the comp. on the hot side)
what do you think?
what do you think?
ha...so ive been lookin into BT manifolds on ebay. and from what i see its not too expensive to go BT. but there is also the tunes.
so how much on average does it cost to do BT MINUS the turbo and manifold and external wastegate.
so how much more would i have to spend once i get the manifold, turbo, and wastegate...to make it run and what would i need? who does a tune for this?...what horsepower range would i be in..
As I told you in your PM, from now on, your threads and posts will be deleted/locked until you prove that you are capable of using the search and can read the stickies. You show no effort of doing either, ever. This is getting OLD
