K03 boosting- - more? ? ?
no, not unless you get an adjustable fpr as well, can change the n75 for a more aggressive one thats like 1-2 more psi, and i've heard of tightening the rod in the wastegate to make it hold a little more... but in short, not really
well if stock is 8-11 and you are pushing 5.. then yeah you can up your boost.. the way to do this is find the source of the leak, and fix it
should allow you more boost (up to the stock levels) but dont try to exceed those levels if you dont have a way to get more fuel in there.. otherwise that baby will run so hot it will go KABLOOEE
