K04-25
Old Oct 28, 2004 | 01:02 PM
David_K's Avatar
Default K04-25
does anybody know if the K04-25 will fit an audi A4 with no problems? I know the K04-15 is a direct bolt on, its just that the K04-25 has bigger inlet/outlets.
Isnt the compressor housing the same on the k04 as the k03
BTW a K04-25 comes off the 225 hp TT
Old Oct 28, 2004 | 05:08 PM
SlimChriz's Avatar
Default RE: K04-25
do you mean is the shape of the housing different? I know the housing is larger but the shape is suposed to be the same. the TT uses a K04 with a longer output thing and it might be oriented at a different angle
Old Oct 28, 2004 | 05:27 PM
clconversion's Avatar
Default RE: K04-25
HaHa I can answer that question as soon as I find out if the turbo is ok off this TT does the K04-25 make more power than the K04-15 ?
Old Oct 28, 2004 | 11:54 PM
trailboss's Avatar
Default RE: K04-25
I thought it is the k04-23 for the 225 TT. I know the k04-23 will fit, but i have heard it is almost impossible to tune correctly.
Old Oct 29, 2004 | 02:55 PM
David_K's Avatar
Default RE: K04-25
no the 23 is for the s4 the 25 is for the 225 tt
and the 25 does make more power than the 15
