Last question b4 buying turbo
ORIGINAL: chaos92287
doesn't the k03s just use the standard k04-15 compressor wheel?
ORIGINAL: cincyTT
Nope. The ko4-15 is the same as a ko3 but with a 2mm increase in the turbine wheel. The ko3s got a larger inducer and turbo inlet along with a more efficient 8 blade compressor wheel (ko3 has 12 blades).
k03s
k04-15
the k04-15 looks the same as the k03s. it uses the same 8 blade design, not the 12 blade design of the k03
ORIGINAL: FasterA4ThanUrs
bobs sig is an e-bj....
Also it doesn't exactly help to know who ripped someone off,when they will never come back,make another profile and post 30 posts and rip someone else off. Case in point that stasis incident. Rather give a shout out to a reputable seller tryin to sell somethin and help him out then bitch about a ghost. .02
Yeah, I might look into this for mine. When are the turbos usually replaced? I'm just under 100k. I know t the better you take care of it, the longer it would last, but you never know. I had been concidering the KO4 when mine went out, but this sounds like a good deal. Does anyone know average hp gains?
ORIGINAL: bob12312357
