Leak ?
Old Jul 23, 2005 | 07:38 PM
Dave666's Avatar
Default Leak ?
I noticed the other day under hard acceleration my APR chipped 1.8T seems to have a 'leaking' sound .
Its loud enough that I can hear it over the turbo spooling . I car seems to be boosting fine .
I dont know what it could be ..
any opinions ?
BTW , I installed my new 710N about 2 weeks ago .
Old Jul 23, 2005 | 10:19 PM
david9999's Avatar
Default RE: Leak ?
Not sure, post a sound clip
Old Jul 24, 2005 | 04:48 AM
luvin_the_rings's Avatar
Default RE: Leak ?
werd...
Old Jul 24, 2005 | 04:55 AM
Nasty's Avatar
Default RE: Leak ?
could it be that you're just hearing the turbo spool louder from the added boost after being chipped?
Old Jul 24, 2005 | 05:21 PM
Dave666's Avatar
Default RE: Leak ?
Hell no , Ive been chipped for a year now ..
Its a 'psssssss' sound . I noticed today I am losing boost too. Car is Slooow.
Almost like stock at times.
Old Jul 24, 2005 | 05:24 PM
Prothymos's Avatar
Default RE: Leak ?
you said you just installed a 710N 2 weeks ago, i would start there, maybe one of the fittings came loose
Old Jul 24, 2005 | 05:52 PM
headshok2002's Avatar
Default RE: Leak ?
Yeppers, pop the hood, listen for a hissing noise... if you dont hear anything, rev it up a bit... and listen again. I doubt that'd be requird. I think you have a vacuum hose thats either off, or broken.
Old Jul 24, 2005 | 06:25 PM
Dave666's Avatar
Default RE: Leak ?
thanks guys .. ill check it out now
Old Jul 25, 2005 | 09:19 AM
lidonnit's Avatar
Default RE: Leak ?
A ssssssssssh signifies a vac hosed that's split. Or the DV has spat the dummy. How much boost you running? Is your car only chipped or turbo upgrade too?
Old Jul 25, 2005 | 12:06 PM
mmart6545's Avatar
Default RE: Leak ?
ORIGINAL: Dave666
Sounds like a boost leak. Id probably do a pressure check.
