leak inside the car
Old Nov 16, 2006 | 11:12 PM
mudpuppu_94's Avatar
Default leak inside the car
I have got a leak in my car now. its in the back floor board on the driver side. i didnt see it comming from the door though. i was kind thinkin sun roof drain line was clogged or something but i dont know. also whenever it floods there is a little spot in the front that is wet too. i would like to fix it myself but i just cant find where its comming from. any ideas?
Old Nov 17, 2006 | 06:39 AM
BzeA4's Avatar
Default RE: leak inside the car
if you've had a boostguage/amp/sub then check the grommet under the ecu box. use some kinda sealant to stop the leakage.
2nd would be the sunroof drains. there's a write-up on AW that shows how to clear them out.
3rd would be the grommet under the battery. but you dont have leak on the passenger side.
Also, i remember reading something about the area close to the cabin air filter.
Old Nov 17, 2006 | 07:21 AM
techbod's Avatar
cabin filter area is the biggest culprit the dirt and leaves build up in there
Old Nov 17, 2006 | 03:38 PM
sandman's Avatar
my car did this and it was the sunroof drains.
Old Nov 17, 2006 | 03:40 PM
techbod's Avatar
as well
Old Nov 17, 2006 | 08:20 PM
thanks!!!!!!!!
and BxeA4...you said there was a post on AW. i cant find it anywhere, do you think you could get me the link
Old Nov 17, 2006 | 08:28 PM
SouRce4's Avatar
same here and in the process of fixing it
thinking its sun roof drain
Old Nov 17, 2006 | 11:29 PM
sandman's Avatar
AW = audi world, its another audi forum.
Old Nov 18, 2006 | 12:28 AM
quattro/2.8's Avatar
This happened to my car not to long ago the problem was there was a hole in the firewall because the guy who installed my sub and amp forgot to plug the hole back up when he was done sending the wires through to the back...that might be a problem 2
Old Nov 18, 2006 | 06:00 AM
ORIGINAL: quattro/2.8
majority of the leak is in the back. and i guess "LEAK" is an understatment!!! i meant to say "FLOOD" the last time it rained here i had about an inch of standing water in the rear driver side floor. it filled in the floor pan all under the seat and everything. it sucked so bad. but im going to start by checking the sun roof drains. thanks for everything guys!
