Leaking Passenger's side headlamp washer 03' B6
Old Apr 21, 2007 | 01:11 PM
AudiOso's Avatar
Default Leaking Passenger's side headlamp washer 03' B6
My passenger's side headlamp washer is leaking. It's very annoying. Anyone else experience this and what does it usually involve? Replacing the whole unit? Fittings? Seals?
Old Apr 21, 2007 | 02:04 PM
kpatz's Avatar
Default RE: Leaking Passenger's side headlamp washer 03' B6
Remove the headlight and see that the hose is attached to the washer correctly. Replace the o-rings, if that doesn't work, wrap some teflon tape around the nipple and then reattach the hose.
Old Apr 22, 2007 | 03:20 AM
porfporf's Avatar
Both sides leak on my car. My mechanic told me that I would need to replace both headlamp pumps. He said that it is probably caused by the summer liquids which are basically water and soap.
Let me know if either remedy works and if it's the rings, what and where you pick them up at. Good luck..keep me posted.
thabiso
Feb 25, 2014 03:34 PM
towerpower
Jul 27, 2010 09:07 PM
HulkB5
Jul 18, 2010 06:04 PM
AK_47
May 3, 2010 01:47 AM
Oafy22
B7 Models
May 12, 2009 12:14 PM
