LED bulbs for interior
I found an old post that had this site http://superbrightleds.com/leds.htm to get LED bulbs from for my interior. Which is great but I really know nothing about bulb sizes and Im not sure what ones I need. I wanna have the interior lighting the same color as the dash. What bulbs would I need for the front 2 over head and back 2 over head lights, as well as the ones underneath the dash that light up the floor. Have any of you matched yours with the dash lights? Oh and its for a 99 A4 thanks!
RE: LED bulbs for interior
here is what you need and this is the link http://www.superbrightleds.com/cgi-b...74&next=50
2- BA9s 4-LED Bayonet Base bulb (Passenger/Driver dome lights) 3- WLED 5-LED Wide Angle LED bulb (center dome light, driver/passenger floor lights) 2- 3910-x6 LED Festoon bulb (two rear lights on the c pillars) |
you made that super simple, thanks a bunch. Have you seen these lights in person? Im wondering if I want Red or Amber to match the dash.
no, just go with the white.. its real clean looking
You might not be happy with red, they will probably not be bright engouh. I currently have red and white (I have it set up so I can used them seperatly) but the red isn't really all that bright.
http://i112.photobucket.com/albums/n...0/IMG_5519.jpg http://i112.photobucket.com/albums/n...0/IMG_5521.jpg If you decide to go with red. Get the brighter chip style. |
That red actually looks like what I want, something not super bright so you can't see through the tint as easy. Is that light count right? I count 2 on the floor, 4 small bulbs in the front and back overhead, and 2 larger bulbs up front overhead.
Yup That's the right amount. Unless you want to add the two above the sun visors.
is there a right about to do these or is plug and play??
look here they are cheaper but they do take a week or so to get to you since they ship from japan
http://stores.ebay.com/warden-jp2002...QQftidZ2QQtZkm the 3910 is a 39mm festoon bulb i have ordered lots of bulb from here and never have had a problem with one answer to ironman they are plug and play the only thing i have found that leds don't work good as are dual use light such as 1157 which are parking lights and brake lights and when using as a turn signal you need to add a resitor to get them to blink at the right speed |
so the interiors are plug in and the eternal needs resistors cool, i plan on doing HIDs and replace brake lights with Bright LEDS that are plug and play
| All times are GMT -4. The time now is 06:41 AM. |
