LED bulbs for interior
Old Sep 18, 2007 | 09:00 PM
CTown's Avatar
Default LED bulbs for interior
I found an old post that had this site http://superbrightleds.com/leds.htm to get LED bulbs from for my interior. Which is great but I really know nothing about bulb sizes and Im not sure what ones I need. I wanna have the interior lighting the same color as the dash. What bulbs would I need for the front 2 over head and back 2 over head lights, as well as the ones underneath the dash that light up the floor. Have any of you matched yours with the dash lights? Oh and its for a 99 A4 thanks!
Old Sep 18, 2007 | 09:07 PM
tooxtreme8813's Avatar
Default RE: LED bulbs for interior
here is what you need and this is the link http://www.superbrightleds.com/cgi-b...74&next=50
2- BA9s 4-LED Bayonet Base bulb (Passenger/Driver dome lights)
3-
WLED 5-LED Wide Angle LED bulb (center dome light, driver/passenger floor lights)
2- 3910-x6 LED Festoon bulb (two rear lights on the c pillars)
Old Sep 18, 2007 | 09:32 PM
CTown's Avatar
you made that super simple, thanks a bunch. Have you seen these lights in person? Im wondering if I want Red or Amber to match the dash.
Old Sep 18, 2007 | 09:56 PM
Lazer Viking's Avatar
no, just go with the white.. its real clean looking
Old Sep 18, 2007 | 10:36 PM
The Bishop's Avatar
You might not be happy with red, they will probably not be bright engouh. I currently have red and white (I have it set up so I can used them seperatly) but the red isn't really all that bright.
If you decide to go with red. Get the brighter chip style.
Old Sep 19, 2007 | 12:10 AM
CTown's Avatar
That red actually looks like what I want, something not super bright so you can't see through the tint as easy. Is that light count right? I count 2 on the floor, 4 small bulbs in the front and back overhead, and 2 larger bulbs up front overhead.
Old Sep 19, 2007 | 08:49 AM
The Bishop's Avatar
Yup That's the right amount. Unless you want to add the two above the sun visors.
Old Sep 19, 2007 | 08:56 AM
ironman's Avatar
is there a right about to do these or is plug and play??
Old Sep 19, 2007 | 08:57 AM
kraylon's Avatar
look here they are cheaper but they do take a week or so to get to you since they ship from japan
http://stores.ebay.com/warden-jp2002...QQftidZ2QQtZkm
the 3910 is a 39mm festoon bulb i have ordered lots of bulb from here and never have had a problem with one
answer to ironman
they are plug and play the only thing i have found that leds don't work good as are dual use light such as 1157 which are parking lights and brake lights and when using as a turn signal you need to add a resitor to get them to blink at the right speed
Old Sep 19, 2007 | 09:09 AM
ironman's Avatar
so the interiors are plug in and the eternal needs resistors cool, i plan on doing HIDs and replace brake lights with Bright LEDS that are plug and play
