Lets debate!!
Old Mar 19, 2007 | 04:03 PM
  #21
Lazer Viking's Avatar
Default RE: Lets debate!!
you would have to upgrade the injectors as well, and there is no point in upping the boost and fuel and not the timing, since there is no way to controll the timing, you would just be pissing into the wind
Old Mar 19, 2007 | 04:04 PM
  #22
The Bishop's Avatar
Ya know what, DO IT and lets us know how it comes out.
Old Mar 19, 2007 | 04:08 PM
  #23
onepoint8tee's Avatar
ORIGINAL: Babz
If the car runs lean is it possible to put in a higher barFPR and adjust the fuel mixture to bring it right???
No... and even if that was possible, what are you going to do about timing? Are you listening? Im done with this.. wow [sm=chairshot.gif]
The way you are trying to go about all this is verywrong.
Old Mar 19, 2007 | 04:09 PM
  #24
Audi_Skydiver's Avatar
Yeah man, your car, go for it and LET USknow your results, but PLEASE do not come crying to us when your engine gives codes or blows up. [sm=violin.gif]
Josh
Old Mar 19, 2007 | 04:10 PM
  #25
Babz's Avatar
Thanx for your input guys. or yea onepoint8tee Already have a manualboost controller and Adjustable FPR so thanx for the link but dont need another one. Catch youz later.
Old Mar 19, 2007 | 04:13 PM
  #26
*Thinking to myself* "This is going to be interesting... It's going to be sad to see another Audi bite the dust"
Josh
  #27
Cool... If you end up trying out your theory, dont bother starting a new thread after you get undesired results.
Old Mar 19, 2007 | 04:18 PM
  #28
Babz's Avatar
LOl. You guys woudnt just speak out by listening to others would youz??? And no i wont start a new thread because i wont have to, been using a MBC at 14psi from 9months ago. have a a/f ratio and it says im running fine. Also spark plugs say im running fine, no detonation or misfires. Car idles fine and holds boost fine. i think im fine. enjoy now ppl. C U.
Old Mar 19, 2007 | 04:22 PM
  #29
Jeff's Avatar
Zombie Defense Force
yes i blew my turbo up. almost blew the motor. mods one the car...only a mbc
Since you guys believe what you say then you gota have first hand experience. Can someone direct me to a link where a MBC has caused nothing but bad things. Any testimonies from anyone???
Old Mar 19, 2007 | 04:38 PM
  #30
Youve made is clear that you dont understand how engine components work... 14 psi with a mbc on an engine without a MAP sensor will lean you out and even if you could get away with not detonating, that 14 psi is doing nothing for you other than blowing useless hot air. You need correct fuel mapping and timing adjustments to take advantage of any added boost over stock (8 psi). If you have a 00+ (with map sensor) I would call you a liar, because the map sensor would see an overboost condition and put you into limp mode (reduced fuel/timing/3-5 psi boost.)
What you are trying to say not only goes against peoples personal experiences, but more importantlyagainst the laws of physics as well.
