Lifting points
Old Sep 28, 2004 | 06:26 PM
dudley doright's Avatar
Default Lifting points
I have done a search on this topic but no results. Does anyone know where is the best spot to put the hydraulic lift jack to lift the car and where to put the jack stand? I saw a post somewhere on the web that shows photo but somehow lost the link. I need to know because the manual is vague indicating where these points are.
Old Sep 28, 2004 | 07:50 PM
Jestnomen's Avatar
6th Gear
Default RE: Lifting points
well on the sides behind the wheels there should be a pad to place a jack. Also you can jack up the car in the middle from the front. You'll see a spot to put the jack.
Old Sep 28, 2004 | 10:53 PM
David_K's Avatar
im not sure about the hydrolic lift, you better be carfull as the a4 is ultra fragile on the underside. if you use the one that came with your car it fits perfectly anywhare on the side of the car.
Old Sep 29, 2004 | 04:44 AM
SlimChriz's Avatar
LOL every time I use the stock jack I laugh at the little one footer its so cute... but there are alot of places you can jack wit the hydralic jack just get under there and look for something beefy that will hold the weight of the car
Old Mar 31, 2005 | 12:28 AM
Auditwins's Avatar
This should be an easy question to answer but it never get a clear response.
The dealer uses a hoist to lift the A4. Where are the lifting pads located???
When we asked a local dealer they won't tell me. Total BS
There must be a lift point layout somewhere to look at.
Old Mar 31, 2005 | 12:36 AM
a4autocrossr's Avatar
dude..you havent figured this out in 6months?!?!?!...just look under the cr...or have someone do it for you..if you've waited this long, it cant be THAT important.....
--E
Old Mar 31, 2005 | 12:42 AM
Auditwins's Avatar
Thanks not really answering the question. I guess you don't know either.
Maybe you watch this post and you get lucky when someone who really knows answers with a clear response.
Old Mar 31, 2005 | 12:45 AM
im holding my breath...
--E
Old Mar 31, 2005 | 12:47 AM
Auditwins's Avatar
Been waiting six months.
Old Mar 31, 2005 | 12:57 AM
Jestnomen's Avatar
6th Gear
do you have a manual?
