Lifting points
Old May 9, 2005 | 03:51 PM
  #21
dudley doright's Avatar
Default RE: Lifting points
ORIGINAL: clconversion
I ushally lift her up on thev oil pan in the front and the gas tank in the rear those are pretty solid lift points
i guess you could do this if you have no sound barrier under the belly of the car!
Old May 9, 2005 | 07:43 PM
  #22
clconversion's Avatar
no no I'm just kidding bud you don't want to do this please don't man
Old May 9, 2005 | 10:17 PM
  #23
Shaunp05's Avatar
I look for the gas and brake lines to hold it steady as i left her
Old May 10, 2005 | 03:49 PM
  #24
I knew you were kidding especially after your last scenario of changing your oil. LOL
Old May 11, 2005 | 04:21 AM
  #25
luvin_the_rings's Avatar
any spot on the framerail is usually a good bet, strongest point on the car...
thats what all the mechanics do on thier 2 post lifts... they just slide the arms under the car, and since the framerail is usually the lowest point on the car (excluding the tranny and exhause), it just lifts up the whole car, while distributing the weight over all 4 contact points, therefore cutting each of the pressures to 25%
all car's are pretty much the same when it comes to this.
correct me if im wrong... but if you really want some stability, just tie some string around roof, and hoist it up like that. its usually pretty safe under there when you do it that way
Old May 11, 2005 | 01:20 PM
  #26
brrman's Avatar
I use the knuckle of the lower control arm.
Old Dec 3, 2005 | 11:00 PM
  #27
Slowb5's Avatar
[sm=dontgetit.gif]
Old Dec 5, 2005 | 06:11 AM
  #28
dankhound's Avatar
Underneeth the plastic the subframe is still in the same spots. You can lift on the plastic if you want. You just have to push on it till you find the solid part of the body. If youve never seen the subframe on the body i wouldnt suggest this as youll wind up cracking the plastic and possibly damaging the floor of the car. When i put my car on the lift i just use the pinch welds on the side. Never had any problems with that.
mike targon
May 21, 2012 07:12 PM
pbc_18
Sep 19, 2008 08:31 AM
AOOOO4
Jun 12, 2008 05:00 AM
impaler2383
Jul 28, 2006 04:34 AM
