Lights
Is there an easy way to take out my oldhead lights or do i have to remove the bumper to get to some of the bolts? (1997 A4)
RE: Lights
Pretty sure you have to remove the bumper. There are two torx screws underneath the housings.
RE: Lights
step one- take off the two torx screws on top
step two- remove corners from the inside by releasing the clip step three- remove torx screw securing headlight from side (hidden by corner piece) step four- disconnect wires. |
RE: Lights
I stand corrected...I'll have to do that when I install my ecodes (I took the bumper off for the installation on my other A4).
RE: Lights
You might also be able to get at the third bolt from the top. Although I am not sure about the 2 piece though.
http://i112.photobucket.com/albums/n...take3light.jpg |
RE: Lights
Thanks..ill try it out.
RE: Lights
One ? is the bracket for the corner's visible, and what does it look like?
