Lights
Old May 9, 2007 | 09:52 PM
Sosa714's Avatar
Default Lights
Is there an easy way to take out my oldhead lights or do i have to remove the bumper to get to some of the bolts? (1997 A4)
Old May 9, 2007 | 09:53 PM
96audia4's Avatar
Default RE: Lights
Pretty sure you have to remove the bumper. There are two torx screws underneath the housings.
Old May 9, 2007 | 10:35 PM
fobyulous's Avatar
Default RE: Lights
step one- take off the two torx screws on top
step two- remove corners from the inside by releasing the clip
step three- remove torx screw securing headlight from side (hidden by corner piece)
step four- disconnect wires.
Old May 10, 2007 | 12:09 AM
96audia4's Avatar
Default RE: Lights
I stand corrected...I'll have to do that when I install my ecodes (I took the bumper off for the installation on my other A4).
Old May 10, 2007 | 12:16 AM
The Bishop's Avatar
Default RE: Lights
You might also be able to get at the third bolt from the top. Although I am not sure about the 2 piece though.
Old May 10, 2007 | 12:28 AM
Sosa714's Avatar
Default RE: Lights
Thanks..ill try it out.
Old May 10, 2007 | 12:30 AM
Sosa714's Avatar
Default RE: Lights
One ? is the bracket for the corner's visible, and what does it look like?
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
