Limp mode?
Old Aug 1, 2006 | 03:24 PM
quiktsi's Avatar
Default Limp mode?
I threw a CEL in my b5 and the code is P0410 (sencondary air injection malfunction) and I was wondering will this throw the ecm into limp mode and lower the boost. The car seems like is boosting normal in low gears but in 4th and 5th it seems a little week. The car is completely stock, I don't even have a boost gage in it so it is hard to tell but I been around turbo cars enough to know what the car should feel like at stock boost in high gears. Is there any way to reset that without having to fix the problem immediately and no I don't have a vag com either.
Thanks
Old Aug 1, 2006 | 04:38 PM
myaudi98's Avatar
Default RE: Limp mode?
You can try disconnecting the battery for 20 min but it might mess up the battery. You should fix the problem cause when you reset the ecm, it will come back on right away and go back into limp mode. Limp mode happens when your ecm notices something wrong and it does it to save the turbo and engine. my boost drops to 2 or 3 psi when its in limp. it barely works at all! My recomendation,,,,, get it fixed first or more problems can arise! hope this helps
myaudi98's Avatar
i meant mess up the radio not the battery. sorry
Old Aug 1, 2006 | 05:38 PM
techbod's Avatar
wiring, air valve fail, air solenoid
Old Aug 1, 2006 | 06:07 PM
quiktsi's Avatar
where is the air valve and air solenoid and how do I go about testing them? someone told me it was the air pump for emissions is that possible?
Old Aug 1, 2006 | 06:27 PM
techbod's Avatar
looks like this, picture pinched of ebay
[IMG]local://upfiles/12092/2ECD9D88FD484ECA8C8D70D1C8CBB9F7.jpg[/IMG]
Pb1700cd
Jun 19, 2011 10:10 PM
ericp1.8T
Apr 28, 2010 08:18 AM
jrock
Nov 20, 2007 05:15 PM
Friar99
Aug 3, 2007 05:54 PM
Indiepunk
Jun 22, 2007 08:42 PM
