limp mode im guessing...?
so a few weeks back my chipped 99 a4 started only boosting to around 3.5-4 psi where as it would usually boost to around 15-16. i figured it was in limp mode and tried disconnecting the battery for half an hour and then driving it. it didnt help at all. i also regularly fill it with 93. this is about the third time this has happened since ive chipped the car, but it usually goes away after a couple days. is there any other methods to fix this besides clearing codes? i dont have access to a VAG so its probably not an option
They have an OBDII scanner that can erase codes. This take you out of Limp mode.
Now do you accelorate hard on the pedal do you notice any issues? Surging? Consider getting sparkplugs. Also you may have a boost leak since 3-4psi isn't much. 15psi is alot and can cause issues.
