AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   a little problem (https://www.audiforums.com/forum/audi-a4-8/little-problem-85308/)
ocielz Dec 19, 2007 10:57 PM
a little problem
well the problem is, when i pump gas my car wont start right away. i've always use 93 octane from chevrom. the thing is when im driving around and i turn it off and then on again it starts perfectly. usually i'll fill up on gas when im at about 40mpg to 45mpg till empty. i've just recently started having this problem, any info. on this????
ocielz Dec 19, 2007 11:24 PM
RE: a little problem
Anybody????????????
a4owner Dec 19, 2007 11:26 PM
Ive also got this problem. My mechanic said it could be the fuel pump on its way out or a gas cap not sealing when it is trying to pressurize the tank
chaos92287 Dec 19, 2007 11:30 PM
got the same problem, nobody could tell me what it was. it has since gone away, which makes me suspect the fuel pump is starting to go
ocielz Dec 19, 2007 11:31 PM
well the cap is always screwd on tight, the weird thing is that it only happens when i put new gas in, then the car wont start right away.
a4owner Dec 19, 2007 11:34 PM
same exact thing but starting it any other time it starts perfect thats why i didnt catch it when i purchased the car
ocielz Dec 19, 2007 11:42 PM
wheres an audi tech. when you need one
Rhinop21 Dec 20, 2007 12:31 AM
Same thing happened to my eclipse, so what do you do when somethings broken? You upgrade of course, so I bought a walbro 255 and a fuel pump relay and the problem went away.
FortyCal Dec 20, 2007 03:30 PM
cheveron sells 93 octane?
razzledazzle Dec 20, 2007 04:00 PM
depends where you live
