a little problem
Old Dec 19, 2007 | 10:57 PM
ocielz's Avatar
Default a little problem
well the problem is, when i pump gas my car wont start right away. i've always use 93 octane from chevrom. the thing is when im driving around and i turn it off and then on again it starts perfectly. usually i'll fill up on gas when im at about 40mpg to 45mpg till empty. i've just recently started having this problem, any info. on this????
Old Dec 19, 2007 | 11:24 PM
ocielz's Avatar
Default RE: a little problem
Anybody????????????
Old Dec 19, 2007 | 11:26 PM
a4owner's Avatar
Ive also got this problem. My mechanic said it could be the fuel pump on its way out or a gas cap not sealing when it is trying to pressurize the tank
Old Dec 19, 2007 | 11:30 PM
chaos92287's Avatar
got the same problem, nobody could tell me what it was. it has since gone away, which makes me suspect the fuel pump is starting to go
Old Dec 19, 2007 | 11:31 PM
ocielz's Avatar
well the cap is always screwd on tight, the weird thing is that it only happens when i put new gas in, then the car wont start right away.
Old Dec 19, 2007 | 11:34 PM
a4owner's Avatar
same exact thing but starting it any other time it starts perfect thats why i didnt catch it when i purchased the car
Old Dec 19, 2007 | 11:42 PM
ocielz's Avatar
wheres an audi tech. when you need one
Old Dec 20, 2007 | 12:31 AM
Rhinop21's Avatar
Same thing happened to my eclipse, so what do you do when somethings broken? You upgrade of course, so I bought a walbro 255 and a fuel pump relay and the problem went away.
Old Dec 20, 2007 | 03:30 PM
FortyCal's Avatar
cheveron sells 93 octane?
Old Dec 20, 2007 | 04:00 PM
razzledazzle's Avatar
depends where you live
