LLTEK Good or Bad?
Alright Ive done a search and havent really found much on the LLTEK D-BOV Shown Here... http://www.lltek.com/DBOV_turbo_divertor_blowoff.htm Is it worth it? will it any problems or worse any damage to the car, which is my main concern since reguar BOV's arent good. What is the recomented pressure I should keep it at since i am getting my GIAC Chip tommrow (ECU + Tranny) Will this blow under normal conditions or will it only blow when I drive hard? Also will the engine run rich when air is released into the air? will this cause Check Engine Light to go on? Thanks for your Input
no matter what your system is going to release air causing your engine to not read it correctly... and to get any real noise your going to have to release a good amount of air... basically its a double edged sword... also i havnt heard good thing about that DBOV... i heard it wasnt the best... if you continue to pursue the DBOV setup id go a different route
lltek is way overpriced as well
Dallas09
Mar 25, 2008 07:25 PM
