LLTEK Good or Bad?
Old Jul 11, 2006 | 12:32 AM
I VIK I's Avatar
Default LLTEK Good or Bad?
Alright Ive done a search and havent really found much on the LLTEK D-BOV Shown Here... http://www.lltek.com/DBOV_turbo_divertor_blowoff.htm Is it worth it? will it any problems or worse any damage to the car, which is my main concern since reguar BOV's arent good. What is the recomented pressure I should keep it at since i am getting my GIAC Chip tommrow (ECU + Tranny) Will this blow under normal conditions or will it only blow when I drive hard? Also will the engine run rich when air is released into the air? will this cause Check Engine Light to go on? Thanks for your Input
Old Jul 11, 2006 | 02:38 AM
StepUpProductions's Avatar
Default RE: LLTEK Good or Bad?
no matter what your system is going to release air causing your engine to not read it correctly... and to get any real noise your going to have to release a good amount of air... basically its a double edged sword... also i havnt heard good thing about that DBOV... i heard it wasnt the best... if you continue to pursue the DBOV setup id go a different route
lltek is way overpriced as well
Old Jul 11, 2006 | 03:43 AM
Slowb5's Avatar
soo...should i get my stick and beat you now...or save it for later? either way man, any sort of venting to the atmospehere is bad for our cars....BAD!. but if you must...i suppose its ok.
Old Jul 11, 2006 | 01:37 PM
I VIK I's Avatar
Thanks guys
Old Jul 11, 2006 | 02:01 PM
smokeU's Avatar
look at the price tag!
Old Jul 12, 2006 | 02:25 PM
I VIK I's Avatar
If the price mattered id be driving a honda...
m3 killer
Nov 22, 2005 08:09 PM
kaklexicon
Nov 9, 2005 06:38 PM
kaklexicon
Nov 8, 2005 07:59 PM
Maverick
May 4, 2004 12:32 AM
