Looking for a vacuum diagram for b5 1.8t
Old Oct 31, 2006 | 07:56 PM
QuattroChucko's Avatar
Default Looking for a vacuum diagram for b5 1.8t
I'm trying to locate a good vacuum diagram for a 98.5 1.8t, preferably complete with labels. I've searched and come up with these two pictures labeled with numbers, but I need part descriptions as well. If anybody can help, I'd appreciate it.
[IMG]local://upfiles/23802/3C897CB6EE7C4688BC8A7F9E08DE1BB9.gif[/IMG]
[IMG]local://upfiles/23802/15B106107D064EFF8E2E107FCEF6A83C.jpg[/IMG]
Old Oct 31, 2006 | 09:58 PM
david9999's Avatar
Default RE: Looking for a vacuum diagram for b5 1.8t
This is for the second attachment:
1 - To EVAP canister
2 - Evaporative Emission (EVAP) canister purge regulator valve -N80-
3 - Check-valve for EVAP canister
between EVAP canister and intake manifold before turbocharger
Installation position (light/dark side): Arrow points in direction of flow, as shown in figure.
4 - Air cleaner housing
with Mass Air Flow (MAF) sensor -G70-
5 - Turbocharger
6 - Combination valve for secondary air injection (AIR)
24-178
7 - Fuel pressure regulator
8 - To brake booster
9 - Check-valve
Between brake booster and intake manifold
10 - Vacuum booster
11 - Check-valve
24-179
12 - Vacuum reservoir
Installation location: Under wheel housing liner in front left wheel housing
13 - Secondary Air Injection (AIR) solenoid valve -N112-
Installation location: Below intake manifold
14 - Crankcase ventilation
15 - Check valve
between Leak Detection Pump (LDP) and intake manifold
16 - to Leak Detection Pump (LDP) -V144-
24-180
17 - Charge air cooler
with charge air pressure sensor -G31-
18 - Throttle valve control module -J338-
19 - Recirculating valve for turbocharger-N249-
20 - Intake manifold
with Intake Air Temperature (IAT) sensor -G42-
21 - Vacuum diaphragm for boost pressure regulation
When the combination valve is opened, the mechanical boost pressure regulation valve in the turbocharger is opened and secondary air is thereby channeled past the turbocharger directly to the catalytic converter
24-181
22 - Wastegate bypass regulator valve -N75-
23 - Mechanical recirculation valve
24 - Pressure control valve for crankshaft housing ventilation
25 - Secondary Air Injection (AIR) pump motor-V101-
Old Nov 1, 2006 | 01:34 AM
dankhound's Avatar
First picture.
1. Hose from airbox to turbo.
2. Arrow showing air coming in from maf?
3,4,5,15. More arrows showing flow.
6. Pcv valve
7. Recirculation hose for diverter valve.
8. Another arrow.
9. Pressure hose from intercooler to intake manifold.
10. Bolt.
11. Manifold air pressure sensor(boost pressure snesor).
12. Intercooler.
13. Duct to guide air to intercooler from front bumper.
14. Pressure hose from crossover tube to intercooler.
16. Crossover tube.
17. Pressure hose form turbo to croosover tube.
18. Vacuum line for diverter valve.
19. Diverter valve.
20. Pipe.
Old Nov 22, 2006 | 06:27 AM
satishtadi's Avatar
Can someone correct these........ numbers doesnt match the components, I narrowed it down.... I dont know 16 ,17, I have doubts on 26,28 etc....
Experts, please correct them atleast the authenticity of the records on this very helpfull forum
Old Nov 22, 2006 | 09:37 AM
david9999's Avatar
25 - Pressure unit
For wastegate
26 - Wastegate bypass regulator valve -N75-
Checking Page 21-57
27 - Mechanical recirculation valve
Checking Page 21-43
28 - Pressure control valve for crankcase ventilation
29 - Secondary Air Injection (AIR) pump motor -V101-
Audi_B5
Nov 5, 2011 06:28 PM
Prizmatik
Jun 20, 2011 02:54 PM
jdahlen24
Jan 19, 2011 03:47 PM
gorac369
Jan 24, 2010 10:28 PM
tdoyle
Sep 28, 2009 11:35 AM
