Loose side marker
Old May 18, 2006 | 03:16 PM
DjSly's Avatar
Default Loose side marker
So I searched the forum but it seem noone had the same problem.
I installed new clear side markers yesterday and everything was fine. After I checked to see if they were solid and while trying to move one that pretty well in place I loose it up. It seems that the gap between the clip and the light is too big hence the fender fints in between.
I revomed them and saw that nothing was broken.
Would anyone of you guys have any tips on how I could tight them up a bit ? I was thinking putting some sort of filling to tighten up the whole but I don't think it will work.
Thanks
Old May 18, 2006 | 03:18 PM
apercele79's Avatar
Default RE: Loose side marker
are you sure the new side markers are exactly for your model car? maybe the year is diff?
i installed new ones and they fit like a charm, thats why im a bit surprised about them not fitting perfectly
Old May 18, 2006 | 04:04 PM
lbraasch's Avatar
i really find it hard to beleive that sidemarkers didn't fit right w/o something being broken or mis-made. I'd send them back, and request new ones. The ones i ordered fit perfectly, and don't know how they could be lose. what year is yours/
Old May 18, 2006 | 04:09 PM
techbod's Avatar
in most cases they are bonded with double sided tape if there is no where to put a screw in, im sure the dealer has come across this problem many times and should be able to get some for you but its simple enough to buy some and make one up, double sided tape
Old May 18, 2006 | 04:18 PM
DjSly's Avatar
ORIGINAL: avant80@2.6
You are the man !! Why didn't I think of this earlier :P This will solve the problem for sure thanks man.
Also in respond to the other it's not SUPER loose just a bit , I sort force a little to see how tight they were and I must have forced to much nothing broke though.
thanks again all
gabe711
Jun 25, 2008 10:56 PM
pattycakes77
May 18, 2008 09:02 PM
Euro S4
Mar 6, 2007 06:35 PM
Optical Serenity
Nov 18, 2006 10:59 PM
ibe3pac
Jan 26, 2006 09:37 PM
