Lost all Boost - HELP - I have the codes
So my car lost all boost on the way home from work today... I ran a VAG-COM and these are the codes it threw... Help !!!! The last code i'm sure is nothing and just was thrown because of the other problem?
Address 01: Engine Labels: 06B-909-518-AMB.LBL Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A Component: 1.8L R4/5VT G 0003 Coding: 0016501 Shop #: WSC 65728 1 Fault Found: 18613 - Performance Malfunction in Cooling System P2181 - 008 - Implausible Signal Readiness: 0000 0000 Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00011 Shop #: WSC 00000 No Faults Found or DTCs not supported by controller or a communication error occurred Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Part No: 8E0 959 433 BB Component: Komfortgerát T7B 1311 Coding: 15212 Shop #: WSC 22309 Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0003 Part No: 8E1959802E Component: Tõrsteuer.BF BRM 0003 Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0003 Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0003 3 Faults Found: 01369 - Alarm triggered by Hood Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01403 - Glass-Break Sensors; Rear 36-00 - Open Circuit |
RE: Lost all Boost - HELP - I have the codes
Start by checking to see if your ecu fuse is blown
my fuses are ok, one of the 15amp ones has a little black on it but so do other unrelated fuses the same size. None of them are burnt in the middle.
Check the Engine coolant temp senor (ECTS) and the thermostat for this code: 18613 - Performance Malfunction in Cooling System
None of those codes should cause you to lose all boost. A bad ECTS can cause alot of screwy problems but I doubt you would lose all boost. I would clear the codes and drive for about 10 minutes and re-scan. |
I had lost most of the boost, it would boost to 2-5psi and that was it. My car never even started to overheat...
reset the code and drove 25mins to work this morning with no problems.. I monitored the car on the way to work and have a data log of the drive. I didn't see anything out of the ordinary. Is it possible that the part is just about to die? What part is the cooling sensor and where is it located in the engine bay? Thanks for the info, much appreciated |
P2186 Engine Coolant Temp Sensor 2 Circ Interm/Erratic
yes the temp sensor would cause problems to power because it cant tell if the coolant is hot or cold and that would put it in limp mode and that's why you would loose boost, the other codes are just alarm and nothing to worry about ( I hope ;)) |
i'm not worried about the alarm codes. .. it just got back from the dealer 2 weeks ago for an oil change and some warranty matience work ... I hadn't run a check since i got it back, so im sure that's where those codes came from....
Yeah it was wierd... At least it wasn't 120 ouside and something was actually wrong with the sensor and the car overheated... that would suck I've only overheated the car once racing myself up a hill in the middle of the day in the summer heat for 45mins driving it hard the whole way up. It ended up just above the 3/4 mark on the temperature sensor and cooled down as soon as i made it to the top... That drive was wayyyy tooo much fun :) |
if you cleared the code for the temp sensor and it didn't come back its probably a bogus code but if it came back I would change the temp sensor
sweet. I was hoping for something like that....
Hopefully it doesn't throw the code on the way home today |
| All times are GMT -4. The time now is 08:58 AM. |
