Lots of smoke. Acts like the pedals stickin. Revs and
Ok here are the codes I got before I erased:
17956
16684
16687
16688
After I erased only 17956 came back up because I have no n75 valve
The other 3 are cylinder misfires, ill try switching coil packs around to see if its a bad coil pack.
17956
16684
16687
16688
You think????? Take your intake ducting/snorkle out and take a pic of the turbo/turbo inlet pipe/pancake valve, where the n75 should beetc. and post it. The story gets more interesting withevery post you make! Also, type in those fault codes in a search engine (one at a time)and see what you can come up with/what they refer to. Then post what you find out.
You are exagerating to prove a point right? I would have searched for a diagram or something after the first 30 mins of not finding it.
ORIGINAL: Noobinator
I spent days lookin for the n75 and its just not there.
no seriously its not in stock location where diagram said, so ive been lookin all over the engine bay for it and cant find it anywhere. Been searchin for about a week now unfortunately. If its not there the car should be in limp mode I belive but it doesnt seem to be.
16684 - Random Misfire Detected - Any Cylinder
or Random/Multiple Cylinder Misfire Detected : P0300
16688 - Cylinder #4 - Misfire Detected
or Cylinder 4 Misfire Detected : P0304
16687 - Cylinder #3 - Misfire Detected
or Cylinder 3 Misfire Detected : P0303
17956 - Boost Pressure Regulation Valve (N75): Open Circuit : P1548
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat) : P1296
