Lots of smoke. Acts like the pedals stickin. Revs and
Old Jul 1, 2007 | 09:18 AM
Noobinator's Avatar
Default RE: Lots of smoke. Acts like the pedals stickin. Revs and
Ok here are the codes I got before I erased:
17956
16684
16687
16688
After I erased only 17956 came back up because I have no n75 valve
The other 3 are cylinder misfires, ill try switching coil packs around to see if its a bad coil pack.
Old Jul 1, 2007 | 11:46 AM
onepoint8tee's Avatar
What is controlling your boost if you have no n75? Ill have to look the other codes up later, or someone else can.
Old Jul 1, 2007 | 12:07 PM
Noobinator's Avatar
EBC i think. I spent days lookin for the n75 and its just not there.
Old Jul 1, 2007 | 12:09 PM
You think????? Take your intake ducting/snorkle out and take a pic of the turbo/turbo inlet pipe/pancake valve, where the n75 should beetc. and post it. The story gets more interesting withevery post you make! Also, type in those fault codes in a search engine (one at a time)and see what you can come up with/what they refer to. Then post what you find out.
ORIGINAL: Noobinator
You are exagerating to prove a point right? I would have searched for a diagram or something after the first 30 mins of not finding it.
Old Jul 1, 2007 | 12:30 PM
Noobinator's Avatar
no seriously its not in stock location where diagram said, so ive been lookin all over the engine bay for it and cant find it anywhere. Been searchin for about a week now unfortunately. If its not there the car should be in limp mode I belive but it doesnt seem to be.
Old Jul 1, 2007 | 12:35 PM
So can you get a pic or not? Did you look up those other fault codes? Get on the ball Noob!
Old Jul 1, 2007 | 12:51 PM
Noobinator's Avatar
16684 - Random Misfire Detected - Any Cylinder
or Random/Multiple Cylinder Misfire Detected : P0300
16688 - Cylinder #4 - Misfire Detected
or Cylinder 4 Misfire Detected : P0304
16687 - Cylinder #3 - Misfire Detected
or Cylinder 3 Misfire Detected : P0303
17956 - Boost Pressure Regulation Valve (N75): Open Circuit : P1548
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat) : P1296
Old Jul 1, 2007 | 01:58 PM
  #18
Lazer Viking's Avatar
i would start with checking your plugs, coil packs and maf.. what year is your car... if you have an icm, that could be your missfire problem
Old Jul 1, 2007 | 02:14 PM
  #19
Noobinator's Avatar
2000 1.8Tq engine code is ATW
Old Jul 1, 2007 | 07:52 PM
  #20
Noobinator's Avatar
im pretty sure im not boostin at all
